Depends what you mean by “struggle”. Usually, once you go above 3.45V per cell, there is very very little additional energy storage to be had. Above 3.6V, even a small amount of current can cause a very rapid voltage rise, and cells won’t stay at this voltage for very long once you stop charging them. So depending on what the struggle is, this might not be a reason for concern.
What is a reason for concern, is that obviously this cell behaves different to the others… right?
I think it is a little more nuanced than that. In all likelihood the manufacturer uses a “binning” practice. The cell capacity is tested and those of similar capacity are thrown in the same bin. Those with a lesser capacity gets thrown in the next bin, and so on. And if you assemble a battery from cells that come from the same bin, they tend to stay in balance with less effort.
But because (on a microscopic scale) no two cells are perfectly the same, nor do they age the same, there will always be small imbalances. But because you started with cells that are very similar, you don’t need a big humongous balancer to keep them in balance. 50mA or so will be enough…
Depends on how the bank is used, and if it frequently sees 100% SOC (3.45v per cell for DIY) where the BMS can balance the cells, as balancing starts on wot, 3.375v or 3.4v depending on settings, it will go slightly out of balance, perfectly normal, the BMS will sort that … with some patience, balancing at milliAmps.
The secret lies in Batched Matched (same capacity and resistance) Grade A (or better quality) should ideally be used on a daily cycled system. Most brand names use top-quality cells.
But, if cell/s go badly out of balance, a cell/s has a problem, as SolarIsDeWay has found. Maybe it can be fixed.
Few tricks one can pull under DVCC, like dropping the charge amps first, to help BMS balance faster on SOC above 90%. Even drop the volts, to help the BMS mA balancing to catch up.
Tibit: 30/50/160/270mA balancing on say like 16 x 280ah cell bank being charged at 10’s of amps … ok.
So one needs to get it right at the start, the cells having close as damn the same capacity and resistance over all the cells, or you will have to pull a few tricks and if you are lucky, even find the “sweet spot” of the mismatched cells. But it is a temporary solution.
This is how it looks, Batched Matched Grade A cells:
Just to clarify these voltages are for LiFePO4 cells..
And yes I agree that Li-Ion aren’t forgiving like lead-acid batteries.
So not only do Li-Ion batteries require a BMS for over/under voltage but they also need a balancing cct.
I’ve come across 18650 battery packs without the latter which causes the battery pack to perform less than full capacity. Has anybody else come across this as well??
Necro-ing an old topic, but some new info came about after I dug into a US2000B earlier this week. So on this bit…
What I learned is that on that balance connector, you will find a white wire in the right-most position. That is the negative side of the bottom cell. The 5 wires that follow after that (to the left) are each attached to the next junction between cells, and should show deltas of around 3.4V-3.5V between each.
If you attach dupont wires to each, you can carefully balance the cells without taking the whole pack apart.
The remaining wires on the connector are – this is an educated guess – most likely for temperature sensors.
HI, Just joined this group, and found you posts very interesting. I am about to try and revive a Pylontech US2000 that I acquired. Total voltage measured inside is around 20V across all three packs, I am guessing that’s why nothing happens when pressing the run, button. I have bought a ISDT AIR8 lipo charger and when the connector comes tomorrow I will be able to connect to each battery pack individually, and charge each pack up to around 16v. But I think it is also a good idea to charge each cell using the ISDT AIR8 S8 charging balance port on my new charger. The port on the charger has 9 pins, so suspect 1 common negative and a positve for each cell ( upto 8 cells ). I was very happy to see your explanation of the balance connector of the Pylontech battery packs, as you said white being the negative on the bottom cell and the 5 pins going to the left the junctions between each of the cells. I would LOVE to find a cable/adaptor to simply plug into the 9 pin balance port of the charger and the other end straight into the pylontech batter pack ( Yeh I know I am hope the something that prob does not exist ), unless you know of such a cable ?. If not is will be a pain getting the correct bare plugs and making a cable myself, Any Ideas ? cheers David in the UK.
