If you just want to know when the grid is down (i.e. Load shedding) then you can use a relay with a 230V coil powered by the grid. Use a normally closed contact to connect power to your light. When the grid is available the normally closed contact will be open and the light will be off. When the grid is not available the normally closed contact will close and the light will turn on. (Power to the light must obviously come from the inverter output otherwise it will not work)
@mariusm , please help me here. If i look at the conditions that Stop/Start the gen in the Generator Assistant, There is no condition that monitors Ac failure. Its load, or battery condition related. Or am I missing something?
There’s a caveat in that AC-Out-2 now directly follows AC1, so it turns off once AC1 is available. The window where the inverter synchronises after AC1 comes back but loads are still on the inverter is missed.
The physically wired relay option will have the same “problem”.
(Btw, you can run multiple generator assistants, just don’t set them to control the same relay.)
That made me laugh. I have that same problem. If I need to do anything, I need to start a Windows virtual machine. And that means I need to make sure there is RAM for it, so it becomes this whole organisational issue… which means someone else can answer this question. I’m glad you did!
I applied this to relay one on the GX using the generator stop / start function on the GX itself without adding assistants in the config file and it works.
Hi all
This is an old thread but I was wondering if anybody has seen a solution built using the Cerbo, a Raspberry Pi and WiFi to control a number of Smart pilot lights placed strategically through the house. The idea is to know at any time whether it is safe to use power hungry equipment (hair dryer, microwave, kettle, drill, etc).
If you can address the pilot lights via wifi there may be a way to do it with Node-RED that can be run on the Cerbo using the large firmware. I am running it to send me a WhatsApp message when the power goes down or comes back and when my batteries reach certain discharge points.
